My sound comes on but no picture.
My sound comes on but no picture. If you put a flashlight on it you can see it very faintly. My model #SLD65A55RQ. Any help would be so appreciated. Thank you very much.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
leshawn234 “If you put a flashlight on it you can see it very faintly “ is a backlight issue. Check your power board connector CON 5 and CON 6 and measure the DC voltages (set your multimeter to 200 Volt) going to your LED’s. If you have proper voltages on your board it will be the backlight array. PITA because you would have to disassemble the panel to get to those. My first suspect is the power board. Let us know what you find out.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 113
