メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Microsoftの最新かつ超強力なゲームコンソールXbox One X(モデル番号1787)は2017年11月7日に発売されました。
Xbox One X No Power
I’ve got an Xbox One X here, and I’m having a bit of trouble with figuring out what’s going on with it. Basically, I can click the power button, and it will beep, but no lights or anything and device doesn’t turn on. The fan doesn’t twitch or spin either. I have also confirmed the power supply is good, which leads me to believe it may be something deeper on the motherboard side.
I’m a little less familiar with the one x compared to the original and one s, does anyone know of any motherboard diagnostics guides for the one x? or any other ideas I may be missing due to my lack of experience with this particular device?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
2 件のコメント:
Have the same problem but my xbox will beep when i click the power button and the light will turn on for 3sec then the xbox just dies. I bought a replacement power supply but it still kept doing the same thing.
さんによる
I just posted a thread about a Xbox one s I have need help figuring something out but I had same issue as you two it turned out if the blu ray drive is plugged in it wouldn’t work and turn on but with blu ray disconnected it’s turning on and working like normal. The power supply and mosfets chips tested good on this motherboard.
さんによる
コメントを追加
1 件の回答
Try checking for any burn marks / corrosion near the power circuit on the board.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
My Xbox does the same thing but my light comes on for one second. I’ve been testing the capacitors. Will let you know what I find
さんによる
コメントを追加
回答を追加する
Tyler Grow さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 21
今までの合計 1,200
