メインコンテンツにスキップ
Released online on January 16, 2009, the Inspiron 1545 is a 15.6" budget PC laptop available with 3 or 4 GB of RAM. It succeeded the Inspiron 1525.
66回答 すべてを表示
1525 motherboard do you have one?
Battery will not charge. Replaced ac adapter, battery and still DC power board still not charging? 1545 is closet model to mine
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Hi @katweise ,
ifixit does not have a motherboard for a Dell Inspiron 1525.
Have you checked whether the DC-In jack is OK and that is not loose from the DC power board or is internally faulty?
Here’s a link to the ifixit Dell Inspiron 1525 DC Power Board Replacement guide.
This shows how to remove the board so that you can visually check if the DC-In jack is loose from the board or test the DC-In jack with an Ohmmeter to prove whether the jack is OK or not.
If it is just loose you’ll have to re-solder it back on.
If the jack is faulty, replacement boards are available online.
Here’s a link to just one supplier
It is shown only to give you an idea of the cost of the part. There may be other suppliers that suit you better. Just search for Dell 1525 DC power jack to get results.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Kathern Weise さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 63
