メインコンテンツにスキップ
Microsoft Corporationが設計したXbox One Sは、2016年8月に発売されました。Xbox One Sは、Xbox Oneを再設計した製品です。
20回答 すべてを表示
Why won't my Xbox power on?
Well, after a power surge while I was away from home, my Xbox wouldn't power on. I knew it was the power supply because it's meant to do that, to protect the other components. But, even after buying a new one off this website for $20, I have replaced the power supply and it still won't turn on. I followed each step by step and finished. But it just won't power on. I've tried the socket, yes it works, the cable doesn't appear damage (plus I used another one to test), but the console won't make any noise or power up whatsoever. What do I do?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
Sounds like a blown VRM (Voltage Regulator Modules) circuit on the board. There are components on the board that make up that circuit to power the logic board. That'll require some circuit level troubleshooting and microsoldering to fix.
For this I think getting another Xbox One S would be the cheaper and option (at least for 2nd hand).
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
That's what I didn't want to hear
さんによる
コメントを追加
If your Xbox Won’t turn on then it might be battery, adapter, or power supply Problem. Therefore, Check one by one for finding the real cause. Otherwise, You have to replace your Xbox.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Jorge Ambriz さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 2,250
