メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Released in May 2018, identified by model number X410ULMG.
My charger keeps falling out and it has to be just right to charge
My LG k30s charger won't fit into the charging port and I've used multiple chargers and it's the same with all of them. Ive looked up how to fix this and every article says there's dust and stuff inside my charger port…there is not, I even tried “removing" what what could've been there but there was nothing. This isn't a new phone or a new charger either. It worked and charged perfectly and then one day it became loose. Please help!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
3件の回答
ベストアンサー
Do you have a case or rubber / plastic sleeve on phone? Try removing that and using a new micro usb charger not from 99 cents store they are made cheaply and easily break. I had same problem doing these 2 easy steps helped another tip dont use phone while charging!
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
From what you've described, your USB port is damaged. I had a similar problem with my Blackberry and the only successful repair was replacing the Port
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
My life sucks beacause of this
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Jacob Long unsuck your life and fix it:-) What phone? What issues? what have you tried?
さんによる
コメントを追加
回答を追加する
cooper unkown さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 12
今までの合計 2,783
