What RAM Memory I need for HP EliteBook 8440p?
What RAM Memory i need for HP EliteBook 8440p?
i have only 2 GB RAM in it an i would update to 4 GB RAM.
Thank you for herlping.
Franz from Austria / Österreich
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Click on “HP EliteBook 8440p” just under the small picture at right of question page. Then click on “Service guide” at bottom of page (scroll down). Go to page 4-16 in table of content. Bob’s your uncle.
このアンサーは役に立ちましたか?
Danke :-) Thank You :-)
Also looks like the builtin ram is under the keyboard and harder to reach but if you upgrade both you can get 8gb total.
SDRAM DDR3 PC3-10600 (1 333 MHz)
You can only put up to 4GB per slot
このアンサーは役に立ちましたか?
You can put up to 4GB per slot, SDRAM DDR3 PC3-10600 (1 333 MHz).
Memory Two customer-accessible/upgradable memory module slots 333Supports dual-channel memory 333DDR3 PC3-10600 1333-MHz memorySupports the following configurations:
■8192-MB total system memory (4096 x 2)
■4096-MB total system memory (4096 x 1)
■4096-MB total system memory (2048 x 2)*
■3072-MB total system memory (2048 + 1024)*
■2048-MB total system memory (2048 x 1)*
■2048-MB total system memory (1024 x 2)*
■1024-MB total system memory (1024 x 1)**Brazil 1333-MHz memory configuration
このアンサーは役に立ちましたか?
You can upgrade it at 16 GB of ram. Personal I use 2x8 GB ram " integral" 1.35v and he work absolutely fine
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 2,685
