Waterproofing S3 after replacing the back cover
Will I be able to re-waterproof my S3 Frontier after replacing the back cover?
Yes, if you use the proper adhesives that meet or exceed the original adhesive. Your install job must be perfect or it’s water resisting abilities will be reduced or nullified.
このアンサーは役に立ちましたか?
Can i ask what adhesive ?
@Cody Tokos B7000 glue is typically used by technicians. Use this glue, clamp it tight and vacuum chamber the phone for best results.
過去 24時間: 0
過去 7 日: 6
過去 30 日: 35
今までの合計 922
