メインコンテンツにスキップ
初代Xboxは、Microsoftで初めて広く普及したビデオゲームコンソールです。上面と前面に「XBOX」の文字が入った黒いケースで、簡単に識別できます。修理は一般的な工具で簡単にできます。
170回答 すべてを表示
2001 Xbox-Whenever I put in a disc it says it pops up error
Hello everyone. I am having a reading disc trouble with the Original Xbox system. Whenever I put in a Xbox disc this pops up “ This is a Xbox game disc. Please put it in your Xbox to start playing” like if you were to put a Xbox game in a PlayStation system. When I put in a DVD it doesn't play the screen just goes black. So it only plays CDs. And Lego star wars the demo on a DVD special. Won't play the movie though. I have tried different Xbox games, I tried flipping it upside down to blow a can of air into the disc reader lens. I took it apart to clean just the lens. Any more tips or Ideas? Thank you in advance. UPDATE I learned that the laser could start not giving enough power to read the disc I put in. So following Youtube I took apart my Xbox to where I could use a miltimeater. Than useing a screw I adjusted it for more power. The youtube video said to keep raising the laser in small amounts so it doesn’t burn out the lens. As I was doing so now the CD drive keeps wanting to open even after I hit the button to shut the CD drive. Any thoughts guys?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
The original Xbox It’s now an old system and disc readers go bad with years. I have 2004 Crystal Xbox and I no longer use discs becouse it wont read the majority of them. I’ve installed a 160GB IDE HDD and now I use it with the evox dashboard, launching my backups from there.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Well before I give up on something I try my best to learn from it. I really would like to figure out what I could do to fix it or make it last longer. At the same time though where do you get what you are talking about? How much it is and how hard is it to instul into my xbox? do you suggest modding it?
さんによる
コメントを追加
@matttia had mentioned that the drive may be broken. However, you can purchase replacement drives online and you then just need to swap the drive out and it should work again. Out of curiosity, does it even sound like it’s trying to read the disc, like can you hear the disc spinning and all that?
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Yes it does up till its done loading. Than after that it says "this is a xbox game please put a xbox in to start playing." after that there is no noise. Thank you for reaching out
さんによる
コメントを追加
回答を追加する
Jacob Tosh さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 9
過去 30 日: 22
今までの合計 1,570
