メインコンテンツにスキップ
iPhoneの5代目となるiPhone 4S。このデバイスの修理は比較的簡単で、スクリュードライバー、開口ツールと忍耐が必要です。GSM/CDMA / 16, 32, 64 GB / 白と黒
2193回答 すべてを表示
iPhone 4s rebuilding the housing and other stuff
Hi I have a iPhone 4s I'm currently rebuilding with new everything like housing screen and logic board but theres one problem I lost all my screws and I ordered replacement on ebay but they are mixed up in a baggy but how would Ik where they all would go and thanks.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
This is very hard. It’s insanely hard to recognize the screws. If you have a diagram that shows where they go,you may be able to judge the shortest from medium sized. Any holes that have the silver ring attached to the logic board are HIGH RISK. If you use too long of a screw,there’s a good chance it will dig into the board and cause long screw damage.
Its really a pain to organize mixed screws. You can look for diy information and see if it tells you which sizes go in which holes and use your best judgement,but know it’s risky if you mess up. I’m not exaggerating.
Good luck!
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Ok it is hard to recognize all them screws I'm still stuck on it and idk where I can find some diy information about it but do u know it's very difficult lol even rebuilding the iPhone but thanks
さんによる
コメントを追加
回答を追加する
Kenneth shawn さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 35
