メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
ジャグジーとはマッサージを目的としたジェット噴射がついたお湯を溜めたお風呂です。
Brand new hot tub will not work
I have a brand new 2019 Catalina Burkeshire six person spa. All the electric has been hooked up correctly with GFI and other required parts. When the breaker is turned on the LED lights come on and the stereo comes on but the pumps will not engage. What is the problem or what can we try to correct this ?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Hey Jeri.
Did you make sure the T Stems on the "Slice Valves" were locked in the open position before and/or at the time the electrical power to the unit was first turned on? If one of these valves was closed at that time there may have been immediate damage to the spa.
さんによる
コメントを追加
1 件の回答
最も参考になった回答
The troubleshooting guide for your spa lists these steps to take if pumps are not working: Air lock - check that pumps are bled of any air.
Pump cycle has ended - press button to turn pumps on.
Slice valves closed - open slice valves.
Check power - check connection in spa control box.
Update (07/21/2019)
Here is a link to the owner's manual:
https://www.google.com/url?sa=t&source=w...
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Jeri さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 4
過去 30 日: 8
今までの合計 213
