メインコンテンツにスキップ
2016年4月27日Amazonより発売された電子書籍リーダー。モデル番号はSW56RW。
18回答 すべてを表示
Touch screen not working
Hello my Kindle Oasis switches on and the two buttons both allow me to scroll through the books I have. What I can’t now doe is to select anything on the screen as the touch screen is not working. Are you able to fix this and if so how much would it cost?
Thanks Kim
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
This is the solution:
Step 1 : Remove the kindle from it’s cover
Step 2 : Heat the screen up using a hair dryer
Step 3 : Test the touchscreen
If the touchscreen isn’t working, keep heating up the screen but make sure to not overheat it as it may cause the screen to leak or worse : the battery to explode.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
This worked like a charm for me. After I heated it with the hair dryer I put it in my dehumidifying camera cupboard to remove any moisture. Now my Oasis works like new.
さんによる
HI, I tried this also, and the touch screen worked brefly. But then it stoped again after minut or so. Is there mabye enyting else to try? Is there some place special to be treated with heat? Is the heat necessery to resolder something inside or?
Thanks
さんによる
コメントを追加
It can be fixed, generally happens when a digitizer fails on the device, but you can additionally attempt to hard reset it by doing these steps:
  1. Press and hold the Power button for a full 40 seconds. After the first 6 to 8 seconds, the screen will go blank, which is normal. Continue holding the Power button.
  2. After 40 seconds, release the Power button. The charge indicator light will turn on after a few seconds.
Hopefully that fixes it, cause unfortunately its not really worth the repair cost on a device of this value.
Have a great day,
Austin
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Kim Churchill さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 19
今までの合計 1,780
