メインコンテンツにスキップ
Appleが発売した第2世代ハイパフォーマンスタブレットコンピューター。2017年6月発売。モデル番号A1670。
41回答 すべてを表示
I accidently dropped my boyfriends ipad and the screen is broken
Hello everyone,
Well I was carrying the ipad inside my back pack accidently dropped my backpack and it had that logitech case with keyboard. which did not protect it. I opened it there were huge spider webs and one big hole on one side. Still works, turns on, I can write on it. But I want to replace the screen for him since it was my fault. So my question is if I try to fix it myself is there any soldering that has to be done? I have fixed macbooks and iphones but soldering is not my thing. I wanted to know if there was another way to fix it or is that a must do step. Thank you for reading my long post. And hoping for a quick reply. =D
Update (07/20/2019)
Forgot to mention the glass is shattered
No soldering needed. I saw this video that it said if you don’t know how to micro solder stop right here and get it repaired somewhere else. Also if I get the screen here would be an Apple refurbished or third party? Worried about the True Tone and range of colors.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
Buy a replacement screen with daughter board pre-installed, so you don’t have to do any soldering.
iFixit is a reputable supplier, you can either buy one here or from MobileSentrix.
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
My bf suggested that as well. So I think I’m going to go with that option. Don’t want to screw it up twice. Thank you for your comment.
さんによる
コメントを追加
最も参考になった回答
just replace the digitizer:
iPad Pro 12.9" 2nd gen Screen Replacement
このアンサーは役に立ちましたか?
スコア 4
コメントを追加
回答を追加する
alma frausto さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 7
過去 30 日: 13
今までの合計 310
