メインコンテンツにスキップ
締切られた回答
Ethernet Port not working-1 wire bent-suggestions?
What is retinning? I spent two hours trying to realign the wire and it looks good but still won't work. Haven't tried any other cables but will–Replacing port is hard/expensive right? USB/Ether adapter?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Apple sells a usb-to-ethernet adapter, but the reports I've seen say it only works with Intel Macs running 10.5.2 or higher. (See the comments here: http://store.apple.com/us/product/MB442Z... )
Not sure if it'll run on a Power PC like your Powerbook, unfortunately.
UPDATE: Actually, it looks like folks have been using the adapter with PPCs, but there may be issues with the 10.5.6 upgrade. Check out this thread for more: http://discussions.apple.com/thread.jspa...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 2,167
