メインコンテンツにスキップ
Xbox 360は、2005年11月22日に発売されたMicrosoft製第二世代ゲームコンソールです。
428回答 すべてを表示
Why is my 360 restarting over and over.
So i have an old 360 and i havent touched it in awhile but recently we want to use it for netflix. It updated after connecting it to the wifi. And then after turning it on now it will run for a little bit then make a click sound and power off and restart, turning itself back on. It will stay on if i dont run any app or game, somtimes. But as soon or shortly after starting a app it will make the click sound and restart. I took it apart and cleaned the years of dust out of it and put it back together and it still does it. Id like to know what i can do to fix it.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Is your Xbox the only thing connected to the Power outlet. Or is there anything blocking airflow in the case.
Are you using the power brick that came with it. Because if not it may be a voltage issue. Thus the Xbox may be restarting for its own safety. Wipe off the power button. Any loose debris can cause the Xbox to falsely mistake it for a finger.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Zach R. さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 4
今までの合計 101
