メインコンテンツにスキップ
The Mazda Capella was commonly known in markets outside Japan as the Mazda 626. The Mazda 626's sixth-generation was built on the GF platform and released in 1997 for the 1998 model year.
53回答 すべてを表示
A/c compressor turning on and off repeatedly?
The system was rather cool but not cold like it was suppose to. I added some freon into the system and it didn't get colder, so I added another on and still, not cold. The compressor keeps turning on and off repeatedly.
What could be the problem?
Thanks you ---Oortism
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Check for leaks. The repeatedly turning on and off is usually caused by not enough refrigerant in the system.
Update
Just added the Heater and A/C section from the service manual for you to download http://www.keepandshare.com/doc/2989167/... It will tell you all you ever wanted to know about your AC system...:-) good Luck
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
oortism08 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,394
