メインコンテンツにスキップ
Galaxy S7 Edgeは Samsungの2016年最新モデルGalaxy S7のスクリーンがカーブしたデザインです。2016年2月に発表、同年3月11日に発売されました。モデル番号はSM-G935です。
369回答 すべてを表示
your phone encrypted for security reason enter password to open you ha
after i update my mobile samsung s 7 edge it's start to startup security log in page says your phone encrypted for security reason enter password to open you have 5 attempt to factory rest i have a lot of data on my phone i do not want to lose please help i do not even remember to setup a startup security before what to do
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 6
コメントを追加
2件の回答
最も参考になった回答
SOLUTION if you have setup a pattern pin lock you have to convert the pattern to numbers. So if you drew a Z in a 3x3 area from top to bottom the password would be 1235789.
Hope this makes sense and helps someone.
Worked for me.
このアンサーは役に立ちましたか?
スコア 7
7 件のコメント:
thank you that worked for me
さんによる
Thanks, it works for me too, but how to change this pattern or password?
さんによる
Oh my goodness, I’m so thankful I found your comment. That did the trick for me. I still had to find out the number of dots on the grid (3 by 3 dots), so I could number it correctly. I should’ve been able to tell from the numbers sequence you provided, but I was a little panicked, lol. You would think Samsung would give some guidance like this for anyone that does a pattern.
さんによる
OMG! this is so brilliant! thank you for the tips!! been trying to unlock my samaung phone for more than 10x and I keep on thinking, wth is my password?? Did I set it up? And Ive come to realized that the password is my unlock pattern!
さんによる
Man... You're awesome. Thank you so much. I can't believe this solution not well known. Your answer deserves more credit.
さんによる
2件以上のコメントを表示
コメントを追加
I find it very strange that an update encrypted your phone. I know the feature exists but you have to manually set it up. Your phone is encrypted by default. This is an extra layer that prevents Android from booting untill set password has been put in.
You can try your unlock code/password/pattern.
このアンサーは役に立ちましたか?
スコア 4
2 件のコメント:
no i do not think it's the update who encrypted my phone someone set the thing manually and i do not remember i did that or not must be my wife she always doing that kind of staff but she do not remember too
さんによる
If you don't know the password there is no way to circumvent it. You can consider your data as lost. Maybe flashing the bootloader and firmware will make your phone usable again. But retrieving your data is going to be difficult/nearly impossible.
さんによる
コメントを追加
回答を追加する
Mohammed Alhijjaj さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 37
過去 30 日: 130
今までの合計 15,278
