starting problem starts then dies when cold rest of day it runs fine.
93 jeep zj starting problem. hard to start when cold, it starts then dies. runs fine and no starting issues during rest of day.
@bshawn could be a fuel issue so check the fuel pump,filter etc. The other things I would definitely check on are the coolant temperature sensor, the air Intake Temperature sensor. Since it seems to happen more when the engine is cold I would focus on that and the fuel.
このアンサーは役に立ちましたか?
Ok I will have that check tomorrow
Even when it's hot after about 20 miles
過去 24時間: 5
過去 7 日: 8
過去 30 日: 12
今までの合計 184
2 件のコメント
@bshawn what engine size and what have you checked?
oldturkey03 さんによる
I just got a used 2009 expedition to
ojojohfred さんによる
