Is there a repair or replacement for the hinge?
The hinge on one side has broken, and the other side is starting to really crack. Is there a repair or replacement for this?
This would happen to our flip phone, but a much older model. I would buy the same model for parts and swap the pieces that I needed. Usually, I would find my replacements on eBay. If it's out of warranty, that would be the easiest thing to do.
このアンサーは役に立ちましたか?
take off front plastic with blow dryer then take off 5 screws then take out careful the screen and take it out remove the bottom 6 screws need to have to get hinge good in the phone you must have phone open when you click it in
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 13
過去 30 日: 41
今までの合計 1,807
1件のコメント
do i need to get a new part?
bdchase さんによる
