メインコンテンツにスキップ
A slow cooker released in 2017 by Crock-Pot Inc. It is the first product of its kind produced by the company. This specific product can be identified by its model number SCCPPC600-V1. The Crock-Pot Express Crock Multi-Cooker has 12 different functions with timer capability.
7回答 すべてを表示
E5 error code but the lid is off
I keep getting an E5 error code, even with the lid off while using the brown/saute setting. Does anyone know how to fix this?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 7
20 件のコメント
Amy Springer did you make sure that the Steam Release Valve is in the “Release” (open) position before starting the cooking cycle.
さんによる
The lid is not even on it. I was using it on the brown/saute setting. Therefore, I did not put on the lid. Taking the lid off would not solve my problem, as the lid was never on in the first place. I still keep getting an E5 error code, which according to the manual, means there is something wrong with the lid. However, I didn't have the lid on and I'm wondering if there is a sensor or something I can replace or another way to fix it?
さんによる
I’ve got exactly the same issue. Does anyone actually have an answer if the lid is NOT on?
さんによる
I am having this problem too! It won’t cook anything, just keeps showing E5 and I’m not using the lid, i just want to brown the meat. Can someone help?
さんによる
Has this been resolved yet? I’ve used mine only a few times & now getting this error message. All the functions on the left hand side aren’t working
さんによる
15件以上のコメントを表示
コメントを追加
9件の回答
最も参考になった回答
Amy Springer  This code appears when either the lid or Steam Release Valve is being used incorrectly for a non-pressure cook setting. Please note that the lid should never be used when using the Brown/Sauté setting.
When using the lid during the Slow Cook or Yogurt settings, the Steam Release Valve must be turned to the open or “Release” position.
If you receive the E5 Notification during any of these situations, then simply remove the lid while using Brown/Sauté, or correctly position Steam Release Valve to “Release” while using Slow Cooking or Yogurt, and then unplug the unit for at least 5 seconds, re-plug it in and re-program your cook settings to begin cooking. from here
このアンサーは役に立ちましたか?
スコア 4
7 件のコメント:
Is anyone actually reading the question? She already said she's not using the lid. None of what is being suggested is remotely helpful.
さんによる
The lid is open, I keep plugging and unplugging and the E5 is still showing... after 2yrs I guess it’s time for a new one... I use it almost every day
さんによる
The picture below is for the Aroma Rice Cooker unit. It is on the outside where the base and the lid hinge when opened. Unplug unit. Remove clear drain cover and unscrew single screw. Pop off black cover. There are two black wires which run from the lid to the base. I just centered them (they were off to the side and getting pinched each time we opened the lid), and then used electrical tape to pin them down and keep them stable. Slip cover back on, rescrew, and you're good to go! Thank you minhdvu2002 for a successful solution!
さんによる
This fixed my E5 problem:
"The picture below is for the Aroma Rice Cooker unit. It is on the outside where the base and the lid hinge when opened. Unplug unit. Remove clear drain cover and unscrew single screw. Pop off black cover. There are two black wires which run from the lid to the base. I just centered them (they were off to the side and getting pinched each time we opened the lid), and then used electrical tape to pin them down and keep them stable. Slip cover back on, rescrew, and you're good to go! Thank you minhdvu2002 for a successful solution!"
さんによる
I actually just split the wires and placed them in the niche space to separate them, and did not tape it down, and it worked.
さんによる
2件以上のコメントを表示
コメントを追加
The wire on cap broken, soldering wire. It working perfect.
このアンサーは役に立ちましたか?
スコア 3
4 件のコメント:
Where exactly is this wire on crock pot express?
さんによる
The picture above is for the Aroma Rice Cooker unit. It is on the outside where the base and the lid hinge when opened. Unplug unit. Remove clear drain cover and unscrew single screw. Pop off black cover. There are two black wires which run from the lid to the base. I just centered them (they were off to the side and getting pinched each time we opened the lid), and then used electrical tape to pin them down and keep them stable. Slip cover back on, rescrew, and you're good to go! Thank you minhdvu2002 for a successful solution!
さんによる
Thanks, I checked and found that wire is broken. After reconnect rice cooker is function back.
さんによる
Same here.. fixed and works
さんによる
コメントを追加
using crockpot in sauté mode without lid showing E5 error which makes no sense as there is no lid in sauté mode what to do?
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
E5 there’s a metal base on the coil. Remove it and woks fine.
さんによる
コメントを追加
Mine had same problem. I ended up calling Sunbeam/Crockpot and they told me it is a chip malfunction and told me to return it for a replacement. Hope that helps.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Mine does the same thing but I found out if you just heat it up first without anything in it it works fine
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
It won’t heat up, that’s the problem. I put the oil in and hit Heat and up comes that annoying E message which refers to the lid but the lid is open as it should be for sautéing.
さんによる
コメントを追加
Hi, I opened the bottom of the pot, unscrewed all the screws, took a picture as it was, and screwed it up again. Everything started to work.
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
I'm getting E5 when I use the sautee feature with cover removed all the time. Unplugged and plugged several times, same code. Is there any solutions to this E5 code.
さんによる
I unscrewed two screws. Works perfectly now. Ty,Elena!
さんによる
Took off bottom. Then unscrewed two screws. Fastened back up again
さんによる
コメントを追加
Unscrew the bottom of the pot with a screwdriver. Disconnect all wires. Then put it back as it was. It should work.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
make sure after you plug in to hit the pressure icon first then saute i don't know if will work for you but it does for me
さんによる
コメントを追加
The lid light keep flashing
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Same issue with my crockpot pressure cooker. So I pulled out the cooking pot and pressed the pot sensor switch a few times and now it's heating up again and no E5 code. Edit. I went to start slow cooking after I used the brown/sear and the code came back. I suspect the safety switch at the bottom is the culprit. So I am trying the slow cooker setting and I have put a small flat washer on top of the switch. My theory is that the button is not being pushed in enough or my pot might be bowing up enough to not push the button down properly.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Amy Springer さん、ありがとうございました!
統計データ:
過去 24時間: 12
過去 7 日: 104
過去 30 日: 471
今までの合計 49,664
