メインコンテンツにスキップ
お庭をメンテナンスするために必要な機械の修理情報
29回答 すべてを表示
Electric pressure washer is pulsing forever when handle is released
Hi!
My power washer (Michelin MPX1900) is having this issue :
1) When I pull the handle and use it to wash, it works fine, strong and steady pressure
2) As soon as I release the handle, the pump just goes “womm womm womm womm womm womm”. It just builds pressure every second and loop forever. I have to turn it off when I release the handle for more than 2-3 seconds because the noise is annoying and I feel like it’s going to break at some point.
3) There is ALWAYS water coming out of the end of the gun when the handle is released. It is low pressure water and the flow is steady (there is no difference if the motor is pulsing or if the switch is “off”). Should there always be water coming out?
Do you guys have any idea?
Thanks!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Hi vizi0n ******- this experiences persistent pulsing even after releasing the handle. This issue might stem from a faulty pressure sensor, a clogged nozzle, or an inadequate water supply. To troubleshoot, ensure the nozzle is clear, the water source is steady, and check for any sensor malfunctions. If problems persist, consulting the user manual or reaching out to Michelin's customer support can provide further assistance in resolving this pulsing matter. Regular maintenance and proper handling can help prevent such issues and ensure optimal performance of the pressure washer
Sources for further reading: https://www.pressurwasher.com/blog/power...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
vizi0n さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 8
今までの合計 31
