メインコンテンツにスキップ
2009年6月発売、2.66, 2.8, もしくは3.06 GHz Core 2 Duo Processor
301回答 すべてを表示
MacBook Pro turns off during boot
I was trying to assist a friend with upgrading his Mac. I added some ram and an ssd. As soo. As I tried to boot it turned on and showed a o with a line through it. “Looked like the sign around the ghost from ghostbusters logo.” I then attempted to put the original parts back in and now that I have done so the Mac turns on, chimes, and then I see the loading bar and Apple then it turns off. I don’t know what do do. It won’t boot into recovery mode with cmd-R and I have tried cmd-d cmd-s and I tried to reset the P-ram. At this point I’m stuck and don’t know what to do…
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
This may have to do with the formatting of the drive. First put the old drive back in and see if the Prohibit Icon is still there.
What system were you running? Did the SSD drive have a system installed on it?
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
The ssd did not contain an os. I installed high sierra on an install usb. I also am replacing the stock 2gb of ram with 4gb I got from a different mac . I put the old drive and ram back in and it wont boot. As I said it shuts off as it tries to boot. where should I go from here?
さんによる
Leave the old drive and RAM in for now.
How to Reset PRAM or NVRAM on a Mac
Shut down your Mac.
Press the power button.
Before the grey screen appears, press the Command, Option, P, and R keys at the same time.
Hold the keys until your computer restarts and you hear the startup sound a second time. ...
Release the keys.
さんによる
コメントを追加
Is it possible that you updated Mac OS with a version that is not supported by your MBP?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Salvatore Lacorte さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 10
過去 30 日: 15
今までの合計 70
