メインコンテンツにスキップ
Kohler makes the gas powered engines for many different riding mowers & garden tractors both for home owners and professionals.
15回答 すべてを表示
Why is my mower not wanting to engage the blades right?
2013 cub cadet 1050. When I engage the mower deck it wants to sputter to a stop. If I mess with the throttle a little it will come on and mow perfectly. Sometimes it just does its little sputtering fit and will engage. New belt, spindles, blades, and fuel filter.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
@stevenstickley make sure that you replace/clean the air filter and the spark plugs. A plugged air filter or faulty plugs can cause the engine to run rich. after you check on that I would recommend checking the choke/carburetor. If the mower still bogs down after that, the problems is most likely a carburetor. A good cleaning of the jets and float (needle valve) and setting the choke should work.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
It runs perfect when the decks off and after the mower finally engages, that's what threw me off a little
さんによる
It sounds like it is choking when you put a load on the engine which is commonly caused by a carb that is running to rich.
さんによる
コメントを追加
回答を追加する
Steven stickley さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 5
今までの合計 98
