メインコンテンツにスキップ
Repair information for the Bose Solo 5 TV sound system. Released in 2016. Model number: 732522-1110.
5回答 すべてを表示
Device not powering up
I bought the above device online, but even after changing adaptors and power sockets, ai can't get the device to power up. The power suppluly is getting the power (got checked) and the device makes a brief sound, but nothing after that. Even bluetooth or power indicators do not come on. What could be wrong?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
5 件のコメント
Hi,
Did you ever get this question answered? Or did you have to fix it?
(I have the same problem also. )
さんによる
me too. it comes harder to get what s going on as the device has not any power button, nor any button at all
さんによる
bose solo 5 requires the remote the unit initially came with in order to turn on. although i just read that you can program a universal remote with the bose frequency codes to use a different remore. I programmed my harry potter RF wand to control it with gesture, flick forward for power , flick up for vol up etc.
さんによる
also, did you try using a multimeter to make sure that the board has clean connections?
さんによる
bose es como los iphones caros $.. para poca cosa que hacen habiendo equipos con precio justo que hacen lo mismo o mejor pero si quieren presumir que tienen dinero pues sigan apoyando MAc o Apple y Bose
さんによる
コメントを追加
1 件の回答
最も参考になった回答
There IS a problem with 20v to 5volt conversion. A circuit called 54335 to changé or solder a miniconverter card instead. Tutorials on youtube
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
See: https://www.youtube.com/watch?v=F0d_mgV5...
It's in German, but has English subtitles with enough info to perform testing and fixing the 20vdc to 5vdc converter defect. If you want info on the defective chip: https://www.ti.com/lit/ds/symlink/tps543...
I will be ordering https://www.mpja.com/Micro-Adjustable-St... as a full PCB replacement for the defective chip.
さんによる
Hi, I have stable 5v output from 54335, but the device is not turning on (the led blinks for a few miliseconds). The IC amp is getting 20v for ~2sec and then it starts to go down to 0v. What can be the cause?
さんによる
コメントを追加
回答を追加する
Rajesh Kumar さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 11
過去 30 日: 57
今までの合計 2,634
