メインコンテンツにスキップ
The LG Stylo 3 Plus is an Android smartphone released in 2017 by T-Mobile. It features a 5.7-inch HD display, 32 GB of storage, and runs the Android 7 OS.
53回答 すべてを表示
Right channel of earbuds works intermittently, however earbuds are ok
I have a pair of earbuds I use with my LG Stylo 3 Plus (LGM-470 TELUS for reference) that only one side will work intermittently; it is the right side, the left works fine, and the inline remote works fine, so it is not the cable on the earbuds. However, if I plug them into a laptop, for example a Latitude 3340, both sides work perfectly. I have a feeling the headphone jack would need cleaning; how can I do so?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
@uv937
a few drops of isopropyl alcohol 90%+ and a few puffs of a pressurized air should clean it. Just hold it upside down while doing so as to not blow to much crud into the phone. If that does not work you may have to consider replacing the jack.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
回答を追加する
Kaleb White さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 41
