Mac pro connect to a 240 volts not 110 it like in u.s.
I just order a Mac Pro Mid 2010 8 Core from eBay.
Can I use the 240 volts plug? ( i use a 240 NOT 110)
if so, i just a adapter to 110 plug
この質問は役に立ちましたか?
この質問は役に立ちましたか?
@baksimcha check the label on your power supply it should be a
Apple Part #661-5449
Performance Connectors
12V Main Connector
Input Current 12 A
Input Frequency 50-60 Hz
Input Voltage 100-240 V
Maximum Power 980 Watts
Output Voltage+12.2V @ 79A
+5Vsb @ 5A
In that case it will be okay to just get a proper cable for your outlet to the power supply.
このアンサーは役に立ちましたか?
Thanks!!!!!!
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 197
