メインコンテンツにスキップ
Brother プリンターの修理ならびに解体ガイド。
How can I fix DCP-J100 printer Clean unable 32 error?
I can print use my printer.It’s show error message ”Clean Unable 32” .I can scan anything use this printer.But I can’t print .Please help me to fix this issue.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
**Read: I know this since I use these printers to scan**
Almost any time you see the Clean Unable error on a Brother, it’s either mechanical in the sense a motor has failed or the waste ink pads are full. The electronics usually do not fail and it tends to be waste ink in most inkjets, regardless of the manufacturer. To rule out a glitch, refer to these troubleshooting steps.
You have one of the lucky few where you lose the print mech, but it stays functional 99% of the way it was before, outside of the on printer copy funtion (more on that later). While it’s days as a printer are over without a new pad (generally totals out the printer) and knowing how to access maintenance mode (and not kill the printer; don’t take chances), it’s still a viable scanner. I draw the line when the print mech is lost to waste ink since it can cause unwanted errors if it tries to run a cleaning cycle, but if the machine has caught this error it will probably not create an issue.
While the fax will continue to work, it relies on the printer part you lost with the waste ink pad being saturated. If you use it, get another printer from Brother that can take the stored faxes (if you need them) and consider the fax dead as well.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Troubleshooting steps don't contain anything
さんによる
コメントを追加
回答を追加する
Shahadul Islam さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 16
今までの合計 2,311
