メインコンテンツにスキップ
Repair guides and support for LED, LCD, HD and other Vizio TVs.
932回答 すべてを表示
I have no picture but I do have audio
Visio E701i-A3
Hello how are you guys I need help I'm having the same problem I have no picture but I do have audio it's the same TV as Brent i did changed the T con but I still dont have picture at all so I'm wondering how can I test the power voltage but what could I be I don't know if you guys can show me.with picture how to measure the voltage on the power board
Update (06/23/2019)
Here is a picture
Update (06/23/2019)
You mean this two ?????
Update (06/23/2019)
I tested the power voltage here is the pic I'm getting 3.38 here I will add the picture
@oldturkey03
Update (06/23/2019)
Here is another pic I unplugged the power supply from the wall and I dont get stand by voltage is that normal here is a picture
Update (06/29/2019)
Hello how are you @oldturkey03 so here I have some pictures of the boards
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
12 件のコメント
Ok today I will take some nice pictures of all the boards thank you so much @oldturkey03 I really appreciate the help thanks so with the pictures you will be able to pointed out were should I resoldering????
さんによる
Check the bottom of the boards where the connectors are soldered to. Sometimes a simple resoldering of those contacts can help.
さんによる
as well as the one to the right of those and the one below that
さんによる
You think it could be the power supply board or not at all ???
さんによる
It's a Vizio so anything is possible. Personally, I think it is less likely and I would check the voltage from power board to main board. I am leaning toward the main board or the panel (hope not)
さんによる
7件以上のコメントを表示
コメントを追加
2件の回答
最も参考になった回答
@victor90ifix okay so your backlight is on you have audio but no video. Check the main board. It is pretty much the only thing left next to the panel itself. Post some good pictures of your boards with your question. That way we can identify the boards and interconnect cables. Vizio had issues with poor soldering of the connectors. You may consider resoldering the cable connectors on the main board.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Hello how are you guys I'm not getting 12 v on the out put from the tcon the ones going to the main board I'm getting 12v but no from the output going to the screen I will take pictures pointing out where I'm not getting 12v @oldturkey03
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
victor galeana さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 2
今までの合計 322
