メインコンテンツにスキップ
Oral-B Pro 1000は充電可能な電動歯ブラシです。
7回答 すべてを表示
Why does motor comes on but brush head does not move
Brush head does not when motor activates
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
2 件のコメント:
I have this issue as well.
The tear down guide doesn't go into the mechanical portion at the head of the brush.
I have mine open and there is an opening on the back inside that allows me to see some of the gears and they look functional. I can't figure out how to get in further to find the malfunction. Specifically, on mine, the metal 'pin' only vibrates. It is missing the up-and-down motion I recall from before.
I guess I can't add pics to the question as I'm not the op?
さんによる
@scottbernardis
Post your comment as a new question on ifixit. That way you can add images.
Here's how to do this iFixitでの質問に画像を追加する方法. It is the same procedure for a new question.
If selecting the same device as shown on this page for your question then your question will also be linked to the device, (see where it says "6 questions View All" in the device box, top right of this page). If you click on that you can see what others have asked about the device and also what answers there are.
Moderator.
さんによる
コメントを追加
1 件の回答
Most likely one of the gears is stripped that turns the brush shaft. You would need to take the brush apart to get a better idea. Here is a tear-down guide to inside the brush. Open it up and post some pictures of the inside if you need more help.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
douglaschamberlain さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 13
今までの合計 433
