What is the E208 error?
Hey,
I have an xbox one X which has suddenly started with a E208 on boot.
Upon searching the net, I can't find anything for E208 even no results on the xbox support.
Any ideas?
You may need to perform a factory reset on your xbox.
Here is the thread where they have the similar issue.
Here is a guide to perform the factory reset.
このアンサーは役に立ちましたか?
I think you should either reset or plug out and then again plug in xbox support panel disk, this might clear your issues. Once this happened with when i was working on my website www.sims4studiodownload.com/family-funds-cheat , i did same and it worked. Thanks
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 13
過去 30 日: 17
今までの合計 12,835
