メインコンテンツにスキップ
Surface Pro 4の後継モデルとして2017年6月発売。別名Microsoft Surface Pro 12.3インチとも呼ばれます。モデル番号はFJT-00001。
51回答 すべてを表示
Bad battery, need to replace
Hello. I think I may need to replace the battery in my Surface pro 2017 if it gets any worse. Two years after I bought it I only get 3 hours of battery life. I see you have a surface pro 4 battery replacement video but I can’t find any specifically for Surface Pro 2017. Do the video and the tools for the Pro 4 also work for the Pro 2017? Any advice would be appreciated. Thanks!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 5
2 件のコメント
My customers surface only turns on when connect to charger
さんによる
I bought a new battery ($50+) then cracked the screen ($200) and then broke the LCD touch screen connector ($10) which I am waiting for. So I’m in it for $260 to “change the battery.” Couldn’t find a place that would do it because the screen tends to crack. Not sure what I would do better next time but you may factor these costs in in making your decision to replace vs. buy new one. I had the same experience as you as far as battery life. I ended up buying a new Surface Pro 7 and am going to use my old one as a back up.
さんによる
コメントを追加
1 件の回答
最も参考になった回答
@ilikegreen I would suggest to follow the guides and teardown from here After that proceed carefully the same way as the Surface Pro 4.
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
Thanks for the advice.
さんによる
I do not see a battery replacement guide help!
さんによる
コメントを追加
回答を追加する
Richard Paulino さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 5
今までの合計 1,528
