メインコンテンツにスキップ
モデル番号A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5もしくは2.8 GHz Core i7プロセッサ
432回答 すべてを表示
iMac Screen Flickering after SSD install
Hi there,
I recently installed a new SSD into our 2011 iMac to replace the hard drive.
All was working fine, however since screwing the LCD back in, the screen flickers consistently.
The brightness is set at maximum, if I reduce the brightness using the keyboard, the screen goes fully black. However I can still see an image behind by using a flashlight directly over the screen. I assume the backlight is not working.
I also purchased and installed a new display ribbon cable however that has not worked. Can anyone suggest anything?
Thanks
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
2 件のコメント
@mayer
Hi! So I replaced the driver board. The flickering still occurs, however I have discovered that the LCD flickers constantly on max brightness now, but on minimum the LCD stays on? Before all I saw was black when I tried to reduce the brightness even by 1 bar.
I'm thinking LCD or the PSU? Can I measure anything with a multimeter?
さんによる
Bump - any ideas?
さんによる
コメントを追加
1 件の回答
ベストアンサー
Time for a new LED driver board:
iMac Intel 21.5" EMC 2428 LED Driver Board
iMac Intel 21.5インチ EMC 2428 LEDドライバーボードの交換
iMac Intel 21.5" EMC 2428 LED Driver Boardの画像
製品
$29.99
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
@mayer
Hi, thanks for the response.
What is the likelihood that it's the driver board? Like I said I just repositioned the screen, (everything was fine) then the flickering occured after next boot.
Some times when I put the new ribbon cable in I get a flash then a black screen, other times it's flickering.
さんによる
On older machines it would be the inverter. The part is cheap and your best bet.
さんによる
コメントを追加
回答を追加する
Thomas Govern さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 5
今までの合計 436
