fuel not reaching fuel filter
The fuel does not reach fuel filter. When you apply suction, fuel comes out of hose. Does this model have a fuel pump?
Completely common for a vacuum powered fuel pump on riding mowers. Follow the gas line from the tank and look for a square ~1.5” “sandwich” with 4 bolts and 3 hoses. Hoses are gas in & out and vacuum pulses coming from the crankcase. Disconnect the hose at the carb and crank the engine - no gas means pump diaphragm has failed.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 1
過去 30 日: 9
今までの合計 304
1件のコメント
What model is it?
Joshua Freeman さんによる
