メインコンテンツにスキップ
2016年9月16日に発売。モデル番号は1778,1784。 GSM かCDMAの32、128、256GBがあり、色はローズゴールド、ゴールド、シルバー、ブラック、ジェットブラックがあり。
1366回答 すべてを表示
iPhone 7 Plus stop charging at 3% after replacing new battery.
My iPhone 7 Plus battery just got replaced with the new one. I forgot to put ‘sticker’ to prevent the battery from moving. after few months the old battery stoped working, I even cannot charge it at all.
After that I replaced it with a new one. It stop charging at 3%.
I opened battery setting, it didnt show at all about battery capacity.
And then I also tried 3uTools, and I cant read the capacity too.
Anyone have a solution?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
There are some tiny components surrounding the battery connector. One of them allows the battery charge state to communicate with the CPU/Charge Circuit. It’s not uncommon to accidentally dislodge components when disconnecting the battery and this is a typical “pry damage” symptom.
Look for R2201 in the image below.
このアンサーは役に立ちましたか?
スコア 3
4 件のコメント:
How should I fix this?
Are you suggesting me to buy a new dock connector replacement?
さんによる
No, you need to determine if the highlighted component is still there. If it's missing, it must be replaced which would require a micro-soldering repair.
さんによる
Hi, I didnt quite understand what is actually "battery connector". I looked at the battery connector on the flex cable and in the motherboard, on my eyes the diagram given is not matching with the one I see. SO maybe I looked at the wrong one
さんによる
FYI: I got a replacement batt, now it charges only till 13%
and then it wont charge againt till it droped 1% and the phone restart by itself
さんによる
コメントを追加
Have you tried other new battery? maybe the battery you replaced was faulty.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
No, I havent. I will send it back to the seller today. I hope its the battery
さんによる
Just try to test your old battery if that charge more than the percent you need, if that goes up means you got a faulty batt.
さんによる
コメントを追加
回答を追加する
Henka Gonzalez さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 4
過去 30 日: 5
今までの合計 317
