メインコンテンツにスキップ
Amazon Fire HD 8(第5世代)は、2015年9月にAmazonから発売された洗練された黒いタブレットです。モデル番号:SG98EG。
38回答 すべてを表示
Why is my Kindle stuck on fire screen?
My Kindle worked fine one day and the next am was stuck on the fire screen. Two days later, my Mom's Kindle did the same thing. Both are charged and no matter how many times I press the power and volume buttons; it always returns to the fire screen.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
4件の回答
最も参考になった回答
Charge your device for at least 30 minutes and try to restart your device again:
  • Press and hold the Power button for 40 seconds.
  • If the device restarts before 40 seconds has passed, release the Power button.
  • If the device doesn’t restart, release the Power button, and then press the Power button again to turn on the device.
If the issue persists, attempt to Factory Reset using the built in device recovery mode:
  • Power device down completely via the Power Button. If the device is unresponsive to the 2-second Power Button press, attempt the 40-second Power Button press, which should cause full shutdown.
  • Make sure your device screen is completely off with no activity.
  • Enter Recovery Mode by pressing and holding Power+Volume Down for 5 seconds.
  • Once in recovery mode, use the volume keys to navigate to "wipe data/factory reset," and the power button to select it.
Please note that a factory reset will remove any content you have downloaded to your tablet.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I have the same issue have been trying for 3 days now. I have done even a factory reset and no luck
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
My tablet is the same have done all the reset, reboot, etc..suggested it will not repair. Stuck on Fire loading screen.
さんによる
Ditto - totally frozen
さんによる
コメントを追加
what to do with my kindle oasis frozen at tree screen, not opening home screen
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I am not a teckie, but my 2¢ worth logic works.
When you switch on, press 20 sec or less only. This will initiate the start. Pressing more than 20 sec causes hanging.
To get out of hanging screen, press the on button for min of 40 sec.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Shelbi Stoecklin さん、ありがとうございました!
統計データ:
過去 24時間: 9
過去 7 日: 65
過去 30 日: 334
今までの合計 26,255
