Lenovo IdeaPad 11s: What size torque screwdriver is required?
Looking at the tutorials, it states you only need a Philips #0 but you need a torque screwdriver but I don't know what size is required? Lenovo IdeaPad 11s
From some research it looks like it might be a Torx 5. A lot of electronics are T3-T6 I’ve noticed, with the exception of some. Try the T5 though!
このアンサーは役に立ちましたか?
Hi,
Torque screwdrivers are used to prevent under tightening of the screw causing it to not hold correctly or over tightening of the screw which may damage the thread or head of the screw.
Looking online torque screwdrivers are not cheap and are usually used by professional repairers as their frequent use justifies the cost of the screwdriver.
If you are doing a one-off repair, it may be just as well to use the appropriate sized screwdriver and simply slug the screws up tight, without overtightening them or damaging the screwhead
このアンサーは役に立ちましたか?
過去 24時間: 2
過去 7 日: 7
過去 30 日: 46
今までの合計 2,247
