Flashing pop up from windows 10. Can I reset it or recover it . ..
I keep getting a windows 10 pop up flashuing a million times. I vant use it. Can i do a restore or reset , or what ,and how?
Are you able to access the windows menu? If so, tap restart while holding the shift key. This will get you to the advanced options menu. From there choose troubleshoot > reset this pc > keep files (erases all 3rd party software) or remove everything (starts you from scratch). You can also follow this guide: https://www.youtube.com/watch?v=hAbx6Ct9...
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 130
1件のコメント
What kind of popup is it? What does it say? I suggest you should find something on the web that relates to the popup that you are getting; iFixIt can help you out as a side associate. Try to provide as much info as possible.
BlueBlue さんによる
