メインコンテンツにスキップ
2.6GHzデュアルコアIntel Core i5プロセッサ(Turbo Boost使用時最大3.2GHz)、3MB共有L3キャッシュ
112回答 すべてを表示
New Battery Is Charging & Recognized, Won't Run on Battery
Just replaced the battery in the MacBook Pro 13” with a new one from iFixIt. The battery shows up at 78% and is charging, I’m watching the mAh increase. The LED on the charger shows orange, as in charging. If I disconnect the power supply the computer won’t run on the battery alone, it must be plugged in, even though it has a charge. Any ideas?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
4 件のコメント
Lets get a better idea on what's happening. Install this gem of an App CoconutBattery Take a snapshot of the main window and post it here for us to see iFixitでの質問に画像を追加する方法
さんによる
Thanks Dan, I uploaded that.
さんによる
Well the battery does appear to be in good condition as you implied.
So that part of the circuit is working so if you now pulled the MagSafe connection he system would just shutdown on its own in a few seconds. Is that correct?
さんによる
@danj Right, if you pull the MagSafe it powers off immediately. Battery has charged all the way up now thouhg.
さんによる
コメントを追加
1 件の回答
最も参考になった回答
Sadly, I think the switching logic which control the power source from the battery to the logic board is not working.
It’s going to take someone with deep circuit diagnosis and access to the needed schematics and replacement parts.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Greg Dietrich さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 92
