How to bypass activation lock
How to bypass activation lock for iphone s6+
この質問は役に立ちましたか?
Actually you need to replace the CPU/NAND/ Baseband CPU and EEPROM. The skill level required to do this consistently is pretty much unheard of in NA and western Europe and the cost factor makes it unviable in almost all situations except where data recovery is extremely important and you are willing to pay a higher price to achieve it.
This can be done more cost effectively on China.
このアンサーは役に立ちましたか?
You will need to replace the NAND, baseband, and baseband memory ICs on the logic board. The chips are BGA-soldered so you will need BGA solder reflow skills and equipment to replace them.
このアンサーは役に立ちましたか?
I was confused so can you help me understand a little bit better?
I was confused so can you help me understand a little bit better please?
このアンサーは役に立ちましたか?
過去 24時間: 3
過去 7 日: 5
過去 30 日: 9
今までの合計 383
