メインコンテンツにスキップ
1996年6月23日に発売されたモデル番号NUS−001の64ビットゲームコンソールです。
114回答 すべてを表示
It works but no sound
I found my chilhood N64 and it did’t work, so I cleaned it and it worked but no sound. I have checked the cables and conectors with a multimeter and they are fine. In my research to find a solution I have found that the capacitors that process the audio might need replacing and that HDMI ultra mod bypasses this problem and does the processing on its own. The HDMI mod its way too expensive for me, so my question is: wich capacitors I have to replace on the board and how do I do it without messing up my N64?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Double check the solder joints on the AV port for any cracks etc. is broke, here is the guide for the port. Check components around U1 which is your MAV-IC Digital to Analog converter (DAC) video/audio. Let us know what you find.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
I have tested the continuity from the board to the end of the cable with a mutimeter, I don't think that's the problem.
さんによる
I have the same problem and haven't been able to figure it out, about to buy a new one.
さんによる
コメントを追加
回答を追加する
machitocayo さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 7
過去 30 日: 43
今までの合計 2,533
