Keurig will not brew coffee
Keurig will not brew coffee, but will dispense hot water. have tried running vinegar through it. Any suggestions???
この質問は役に立ちましたか?
この質問は役に立ちましたか?
gmilano@me.com you did not tell us what happens if you place e Keurig Pod into the machine. If it sounds like it works but does not brew, start by simply taking a look at this Keurig Coffee Makerの分解と洗浄方法 Different model same idea. If your waterways are partially clogged there will not be enough pressure to force through the pods etc.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 12
今までの合計 1,539
