メインコンテンツにスキップ
Virtual reality headset released by Acer, built around the Windows Mixed Reality platform. Model AH101-D8EY.
No display when headsets turned on
When I turn on my headset everything loads except the display. Hearing and tracking is fine but I can't see anything. I know my computers not the issue because I tested it on a friends computer.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 4
コメントを追加
2件の回答
最も参考になった回答
im having this issue too, started when i put the visor down after typign on my keyboard. immediately lost sight and it was tracking perfectly. based on what ive dug up it seems to be the cable. also i was able to switch the refresh rate several times and get it to work, then when i even slightly moved the visor it immediately went to black. there is no replacement cable as far as ive seen this is probably a situation where youll have to take it apart and fix the cable another way.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Ya, Every time I plug it in it tracks perfectly fine. But when I put it on the display is just pitch black
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Mystery Drago さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 9
今までの合計 559
