メインコンテンツにスキップ
The HP Compaq 2510p, model number "GM651AW" and was released June 2007. It features an Intel Core 2 Duo ULV processor and 12.1 inch display.
4回答 すべてを表示
My laptop won’t charge.
My laptop won’t charge and displays a steady white light and a blinking yellow light on the charging led. Whenever I take out the battery it still won’t turn on. I even tried replacing my charger although I don’t know if the one I replaced it with is compatible with it although there the same brand. I need help on fixing this cause it’s not even my laptop but my sisters laptop and I have not told her it isn’t working as yet.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
@romainedwyer check your AC adapter with a multimeter to make sure that you have the right voltage. The brand is irrelevant for as long as the specs are the same. For this laptop you will need a 65Watt 18.5V 3.5A power adapter. Let us know what you have.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Romaine dwyer さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 3
今までの合計 182
