メインコンテンツにスキップ
Televisions made by the Chinese multinational electronics company, TCL.
264回答 すべてを表示
No video but sound is on when watching tv channels
When I watch tv channels after few minutes the screen goes black but sound is on, but when I Watch Netflix or Kayo for hours nothing happens. Did the reset from service menu still no good, any thoughts??!!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Please see the pic, that’s how it’s looks like when the image stops showing, sound is still on.
さんによる
コメントを追加
1 件の回答
ベストアンサー
ishtiaque789  since you already reset everything etc., I would check the backlight next. In a darkened room shine a flashlight at an angle against the screen. Make sure that the TV is on and that you get sound. If you can make out shapes and silhouettes then you know that you are having a backlight issue. This could be related to a bad power board or a bad LED backlight array. For more info we would need the exact model of your TV. Also, if you can remove the back from your TV and post some good pictures of all the boards and the interconnect wiring. iFixitでの質問に画像を追加する方法
Update (06/02/2019)
ishtiaque789  your backlight is on. Since it works when you use Netflix etc. my number one suspect would be the main board. Change that one and let us know what you find out.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Technician came from TCL and changed the T con board, it’s fixed now.
さんによる
コメントを追加
回答を追加する
ishtiaque789 さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 2
今までの合計 1,463
