Soldering small touch connector
Has anybody replaced the small touch FPC connector on the iPad 6?
I noticed this style connector doesn’t have the legs protruding out wards but attaches directly underneath.
Any pointers?
Thanks
この質問は役に立ちましたか?
Any pointers?
Thanks
この質問は役に立ちましたか?
You’ll have to solder it back using hot air. This, of course, presents its own challenges ;>).
The trick to soldering plastic connectors with hot air is to:
Good luck!
このアンサーは役に立ちましたか?
I thought as much
Thanks
If you found this answer helpful, please select "Was this answer helpful? - YES" and/or if this answer solved your problem, please “Choose as Solution”. This allows people in the future to understand which answers helped solve the problem and adds value to the site. - Thanks
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 100
