メインコンテンツにスキップ
The QiCycle Folding Electric Bike is Xiaomi’s first foray into the world of e-bikes. It has a 250W high-speed motor powered by Panasonic 18650 lithium batteries. The Shimano Nexus 3-speed gear hub in combination with the torque measurement sensor gives you up to 45km bike power on a single charge. It also has a trip computer can connect to your smartphones via their special app and is–of course–foldable.
20回答 すべてを表示
My Qicycle suddenly has no power assist
The battery level shows it is full and the LCD display shows up normal. Now it is just an ordinary bike with no power assist. The LCD display still shows the speed and watts of the bike when I am padel the bike. The bike has only 150km. Which component I should replace first or how to narrow down the faulty unit? Bike Control unit, torque sensor or the motor?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 4
1件のコメント
I have gone through the IFIXIT tear down tutorial of the bike and there are no fuse to replace.
さんによる
コメントを追加
6件の回答
最も参考になった回答
Hi, did you solved the problem? I have same one…
このアンサーは役に立ちましたか?
スコア 1
8 件のコメント:
Problem solved! Brake sensor was defected. If there is someone who will have the same problem, just try to disconnect the left & right brake sensors (connectors) between pedal...
さんによる
Si,correcto. Sólo desatornillé el sensor del freno izquierdo y funcionó,gracias.pd. Error de fabricación
さんによる
what brake sensor are you talking about ?
さんによる
@Michal Procházka : what break sensor ? mijia qicycle only has manual break. is there any sensor ? where? can you post a photo here, please ? thanks
さんによる
Hi, I have brake sensors under brake lever. The sensors scan brake lever level and when you are braking, it send information to the controller and then controller stop output power to engine... But I have EU version, so, If you haven't wires under brake level, you probably don't have brake sensors.
さんによる
3件以上のコメントを表示
コメントを追加
Watch YouTube for Xiaomi qicycle fr Dyson bike they found the sensor plug just need tighten n simply…I fixed mine hope it helps
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Chinese qicycles dont have brake sensors...
さんによる
My qicycle has wires coming out of the brake levers right and left.
さんによる
コメントを追加
I have the same problem also. Several e-bike service center don’t know the problem. They said xiaomi too complicated bike and no parts available in my country (jakarta - indonesia). Yesterday I went to another e-bike service center. The technician said he will check one by one. And just know he texted me, he found the problem. It is THE CONTROLLER. And now he is trying to replace with the one that he got in his store. Yes, he will try to modify or whatever to fit the new controller. I hope this will work.
このアンサーは役に立ちましたか?
スコア 0
6 件のコメント:
Hi there, i am.living in Jakarta and I have the same problem. Please advise me your ebike service center. Thx
さんによる
Trektown. Please check via google. The phone number I got from google. The technician name Abenk
さんによる
Hey, would you be willing to share your contacts for the e-bike service center in Jakarta?
さんによる
The store name TREKTOWN at Lebak Bulus. You can google for the right address. The technician name is mr. Abenk
さんによる
My qicycle now work perfectly. The problem is the controller. It is locate beside the battery. Only good technician can take it out and fix it. The technician told me to be careful with the controller by not push the bike to hard. It means we cannot use gear 3 when the street is high. Use gear 1 and push the pedal wisely. I hope you understand my english.
さんによる
1以上のコメントを表示
コメントを追加
i‘ve had this problem two times.
First time the mud defender i have installed killed one little cable between the motor and the controller. The second time it was more difficult. qicycle app beta told me that one battery cell had 41volts, the other 0 volts. ….but the battery was working in another bike.
I have changed the integrated cable, then the controler, nothing. At last i have changed the computer at the handlebar. That‘s it. The computer was okay, only the yellow cable was broken. Folding a bike is no fun for the cables.
Hope i could help you.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
You have to check the controller. And… it really hard to check it. It locate behind the front lamp. Only an experiece tehnician can do that.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Hallo!Ich habe das gleiche Problem,habe Controller und Display getauscht aber will nicht Funktionen.Kann Mann für normal Fahrrad benutzen.Wo hat Fahrrad Problem,was soll ich tauschen…Motor..oder welche Sache?
Danke euch.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Sinclair Yung さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 26
過去 30 日: 62
今までの合計 8,675
