メインコンテンツにスキップ
Released February 2012, identified by model number 26299
13回答 すべてを表示
Lense not opening , showing lense error , also having cluttering sound
Few days back my nickm l26 was working properly but then there was a dust strom and as far as I know camera was out without cover .
So when I try to start it ,nothing happened ,
There was a cluttering sound (continuous).
And screen was showing lense error
Battery was full I try to recharge it and try again but did not work.
I also tried cleaning lense sides with small paper but nothing
So is there any other way ?I did not want to buy a new one
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Sarandeep Singh a dust storm could do it. You may have all kinds of debris on the extension barrel for the lens. You can try to clean it etc. Check on here for some idea on how to possibly fix it. Ultimately I would consider changing the lens since repair parts for the lens are not readily available. It is not a very challenging job and can easily be accomplished. Use these guides Nikon Coolpix L26 to work on it. Luckily the Coolpix only have minor deviations when It comes to changing the lens. Check this video
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Sarandeep Singh さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 71
