メインコンテンツにスキップ
Repair information and support for the Acer Aspire E15 laptop, released from Acer in 2015. Model number: E5-575-33BM.
20回答 すべてを表示
Does not shutdown or restart
Hello friends,
The laptop does not respond to the shutdown button or restart button on the start menu. The power button also not working. It only can hibernate and sleep. Could not work with it because it is stuck and continuously warning me to update. I try several ways which i found online. But none of it works. The only solution I can see is formatting and install windows 10 again. Can anyone tell me why is this happened and any solution I can try before format it again?
(Because I formatted it recently like month ago)
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Thats win10 for you. If possible I would recommend downloading latest win10 ISO (on official webiste) and reinstalling the system completely… I had similar problems with Windows10 v1511, and only thing that fixed it was clean system install.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
I was going to boot my pen drive and restore windows. Would that does not fixing the issue?
さんによる
Well, if you portable/live/bootable OS is Win10, and shutdown works, it can be only one thing - Windows 10 (as usual). Restoration may not fix the problem so this is why I usually suggest clean install if possible. Tho it occurred to me I had similar problem with few laptops that had (busted) card reader, but this is probably unrelated.
さんによる
コメントを追加
回答を追加する
Elsa Bailey さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 209
