Values of missing components
Hi to all,
I need help with PS4 with broken HDMI port. Behind HDMI port there are missing few components, as far as I can tell, one diode and 2 resistors are missing. Does anyone know values of missing components?!
Thnx
Hi, the top “piece” out of the three missing is a diode and the other two are resistors. The PS4 will work without the diode, but those two capacitors are necessary. I had this same problem. I'm not sure of the exact values, but you can buy the HDMI portion as a donor piece on Ebay and just transfer the components over. Below is the Ebay link, I hope this helps.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 388
