メインコンテンツにスキップ
2016年9月16日に発売。モデル番号は1660, 1778で GSM かCDMA があり。/ 32、128、 256 GB / 色はローズゴールド、ゴールド、シルバー、ブラック、ジェットブラック
2265回答 すべてを表示
Why is my iPhone stuck in 1% and restarting itself every few minutes?
So i wake up this morning and i dropped my iphone 7 from the bed, i went back to sleep and when i wake up my phone was on 1%,I tried charging it but it shows 3% or 5% and it restart itself every few minutes and the apple logo appears 2 times and it shows again 1%,the battery health shows "the iphone is unable to determine battery health", it was 84% before this happened.I tried to charge it after that and it go to 100% directly before to restart and when it restart it's again 1%.
i changed my screen 2 months ago.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
Hmm if you changed your screen, did you replace the plate over the battery? Open it up and disconnect and reconnect it. Maybe it just jostled apart during the fall. Try that, and let me know how it goes :)
このアンサーは役に立ちましたか?
スコア 1
4 件のコメント:
it wasn't me who changed i took my phone to a repair shop. but i think that may be the problem.
さんによる
Then yes, I would take it to the shop where you got the screen changed. Let them know the problem, and the suggested solution. I have ran across this problem many times at my shop.
さんによる
thank you i will, i hope i don't have to change the battery .
さんによる
No problem. Hopefully you don’t (:
さんによる
コメントを追加
Such problem accedentily happen by the following region.Actually that is related to SWI Line problem.
1- Battery must have problem.
2-Battery connector
3- Loose contact of battery to battery connector SWI line.
Battery have 3 pins,one is +ve,-ve & SWI.
On that cases if the problem still same after doing this you have to follow this process but remember need micro-soldering skills.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
lor mo さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 9
過去 30 日: 45
今までの合計 1,482
