Can I use ethyl alcohol?
can I use ethyl alcohol 70% to clean my device ?
You can, but the high vapor pressure means it will evaporate much quicker than an alcohol more suited to cleaning like isopropyl. Make sure it doesn’t contain any other chemicals that could be left on the device when the alcohol evaporates.
このアンサーは役に立ちましたか?
thanks for answering
Please look at this question: What are Professionals Using for Screen Cleaning
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 9
今までの合計 479
5 件のコメント
ethyl alcohol is for drinking. A 70% would be 140 proof. Just what do you have?
mayer さんによる
I bought it from the pharmacy It's used for medical purposes And product name is (PURE Nautre's Purity)
Amr Ateef さんによる
If its pure, then you should use it. My answer is YES!
Kon Dev さんによる
I would strongly recommend using isopropyl rubbing alcohol as, it does not leave as much of a residue as ethyl alcohol can. Electronics are very sensitive.
John Potter さんによる
Thank you for helping me. I will use ethyl alcohol in this period then Later I will try to get isopropyl alcohol to avoid any damage
Amr Ateef さんによる
